Arash Report post Posted 11/06/2004 01:11 PM Hi All, I've just attached a PINE (Rockwell Chipset) Voice modem to My Test PC. The problem is , it doesnot recognize end of call tone , when we drop the phone line we hear fast busy tone at the end of our message till the message timeout reaches. Does anyone have any idea about it? Regards, Arshak Share this post Link to post
SupportTeam Report post Posted 11/06/2004 10:40 PM If the modem does not recognise the busy tone then the only thing you can do is change your modem - or just get a Dialogic card. Share this post Link to post
Arash Report post Posted 11/07/2004 06:41 AM hi and thank you for your respone, ive tested the modem with other IVR softwares and it detects fast busy with other ones, is there any setting in voiceguide for this option ? ive seen in your website that Voice Guide works with voice modems. thank you Regards, Arshak Share this post Link to post
SupportTeam Report post Posted 11/07/2004 06:57 AM No software has control over modem's ability to detect busy tones etc. there are just no commands that modems have that can be used to adjust the frequencies/cadence etc of the tones for which the modem should be listening. The only way to get better tone detection out of the modem is to play quieter sound files - the modem can then better hear 'busy' etc. tones over the noise of the sound files played. Share this post Link to post
Arash Report post Posted 11/07/2004 03:09 PM tnx for your reply. let me explain more, I have a 616 analog PBX (panasonic) which is connected to my modem. (Conexant Internal modem) everything is ok, I can transfer lines, record voice messages, use ivr menues, etc... the only problem is, when a caller hangs up, the modem doesnot hang up. and the line became busy till it times out. (I can hear the fast busy tone generated by pbx at the end of messages.) I want the modem and vg to detect the fast busy and drop the line then. tnx for your support, Regards, Arshak Share this post Link to post
SupportTeam Report post Posted 11/07/2004 08:17 PM As mentioned before, there is nothing that can be done to alter how well a modem detects busy etc tones during recording... Share this post Link to post
